Good Afternoon all.
For some background info. Ignition is installed on a remote server. (IT Controlled). I bring the Gateway up in my local browser, and launch designer from there. The application I built is a simple dashboard. I have two OPC tags linked to two text boxes.Under the property change script for both I have very simple queries to populate a couple of tables. The OPC tags have a refresh of two seconds through Top Server.
When I run the application inside the designer it will run non-stop never indicating an issue. When I run the application in staging it will have time of running good. Then through the diagnostic tool I will see some warnings about Gateway connection, and then it will loose connection. I don’t know if the is a network issue, or something else. If anyone has had this happen or is familiar with the issue let me know. Thanks in advance. Below is the error I recieve.
Message Connection to Gateway lost, due to exception.
Time Wed Mar 13 1:20:18PM
Severity WARN
Logger com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager
Stack Trace com.inductiveautomation.ignition.client.gateway_interface.GatewayException: connect timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:501)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:273)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:894)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager$GatewayPoller.poll(DatasourceTagManager.java:679)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager$GatewayPoller.run(DatasourceTagManager.java:592)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketTimeoutException: connect timed out
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:394)
… 12 common frames omitted
