Running Windows 7 64 bit. I used the Windows installer on top of a running installation. Gateway “main” shows a “faulted” context even after a GCU restart.
It appears that the whole Ignition context is failing to start due to an XOPC driver error. From the gateway logs (attached):
java.lang.NoClassDefFoundError: com/inductiveautomation/xopc/driver/management/DriverMeta
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at com.inductiveautomation.xopc.drivers.module.XOPCDriversModuleHook.(XOPCDriversModuleHook.java:32)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
(ctd in log) Gateway.log.html.txt (68.4 KB)
There may have once been a Dev version on this machine. The last working version was production. I haven’t touched it since the gateway failed to start. From an existing “install_log.txt” that somehow didn’t get overwritten during the upgrade:
[quote]Log started 03/28/10 at 12:38:34
Preferred installation mode : win32
Trying to init installer in mode win32
Mode win32 successfully initialized
Executing C:\Program Files (x86)\Inductive Automation\Ignition/stop-ignition.bat
Script exit code: 0
Script output:
wrapper | Stopping the Ignition Gateway service…
wrapper | Waiting to stop…
wrapper | Ignition Gateway stopped.
Make sure that all of the modules are the same build number. You can check this in the gateway config section under Configuration -> Modules. The build number is below the version, eg. b5058. If they don’t have the same build numbers you can download the modules from the current release downloads section of the website and install them manually. One thing to note, we renamed the OPC-UA drivers module to Allen-Bradley drivers. See if this fixes the issue.
