We changed our Ignition port over SSL 8043, instead of 8088. We got everything working including our raspberry pi’s. The only problem we have left is the Gateway Control Utility on our server shows our web server and gateway not started and not running. But in services the gateway is running, and everything is working fine. After trying several times opening the Gateway Control Utility it will show started and running. But if you open it right after that it goes back to showing not started and not running. Any Ideas? Thanks
