Hi all,
We have a Siemens S7-1500 communicating using the new driver.
There are a handfull of tags communicating successfully with the driver.
When we browse the device to add a tag from scratch (I.e. Add tags popup, hit refresh so no folders are open), during drill down of the folders, the whole gateway crashes.
Looking at the logs:
INFO | jvm 1 | 2025/07/31 14:47:30 | # A fatal error has been detected by the Java Runtime Environment:
INFO | jvm 1 | 2025/07/31 14:47:30 | # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff804705982, pid=5260, tid=7048
INFO | jvm 1 | 2025/07/31 14:47:30 | # JRE version: OpenJDK Runtime Environment Zulu17.58+22-SA (17.0.15+6) (build 17.0.15+6-LTS)
INFO | jvm 1 | 2025/07/31 14:47:30 | # Java VM: OpenJDK 64-Bit Server VM Zulu17.58+22-SA (17.0.15+6-LTS, mixed mode, tiered, compressed oops, compressed class ptrs, g1 gc, windows-amd64)
INFO | jvm 1 | 2025/07/31 14:47:30 | # Problematic frame:
INFO | jvm 1 | 2025/07/31 14:47:30 | # C [AGLink40_x64.dll+0x235982]
INFO | jvm 1 | 2025/07/31 14:47:30 | # No core dump will be written. Minidumps are not enabled by default on client versions of Windows
INFO | jvm 1 | 2025/07/31 14:47:30 | # An error report file with more information is saved as:
INFO | jvm 1 | 2025/07/31 14:47:30 | # C:\Program Files\Inductive Automation\Ignition\hs_err_pid5260.log
I have the hs_err_pid5260.log but am unsure the best way to share it.
The error is quite repeatable, so can provide any additional information /logging as required!
Its always the frame [AGLink40_x64.dll+0x235982] when it crashes.
This may be vaguely related to [null, Bad_NotConnected(“Communication with the data source is defined, but not established...] as we're also having this issue, however with it crashing the gateway I didn't want to hijack the thread
Thanks!
Alex
