I have the right time zone and time in the SERVER where the ignition is installed but checking the Gateway time this is wrong (but it shows the right Timezone) , any ideas how to fix it?
thanks
thanks
Upgrade to the latest available version of Ignition.
When the Mexico DST change happened it required an update to the TZ database, which is distributed as part of the Java runtime, and we keep the Java runtime up to date in Ignition releases.
thank you
