Time in the Gateway diagnostic logs isn’t matching the Designers gateway tag. No idea what’s going on here. Any help?
It looks like you may have the same issue in your post as the one below.
(I intentionally deleted the h in the http below so as not to give the machine a chance to grab the first query in the other post )
ttps://forum.inductiveautomation.com/t/datetime-is-different-between-ignition-and-plc/27289
Your timing is only slightly behind the other post.
As always, if you are in a hurry then you could check
https://support.inductiveautomation.com then the Policy section for support
