INFO | jvm 1 | 2024/08/30 17:06:51 | I [g.IgnitionProjectManager ] [17:06:51.013]: Setting LastModification to "external" on Ignition_Training/Main Windows/Settings [com.inductiveautomation.vision/windows]
INFO | jvm 1 | 2024/08/30 17:06:51 | I [g.IgnitionProjectManager ] [17:06:51.013]: Setting LastModification to "external" on Ignition_Training/Navigation [com.inductiveautomation.vision/windows]
INFO | jvm 1 | 2024/08/30 17:06:51 | I [g.IgnitionProjectManager ] [17:06:51.013]: Setting LastModification to "external" on Ignition_Training/Popups/Popup [com.inductiveautomation.vision/windows]
INFO | jvm 1 | 2024/08/30 17:06:51 | I [g.IgnitionProjectManager ] [17:06:51.013]: Setting LastModification to "external" on Ignition_Training/User Management/Switch User [com.inductiveautomation.vision/windows]
INFO | jvm 1 | 2024/08/30 17:06:51 | I [g.IgnitionProjectManager ] [17:06:51.013]: Setting LastModification to "external" on Ignition_Training/singleton [ignition/global-props]
INFO | jvm 1 | 2024/08/30 17:06:51 | I [g.IgnitionProjectManager ] [17:06:51.013]: Setting LastModification to "external" on Ignition_Training/singleton [mobile/mobile.project.settings]
INFO | jvm 1 | 2024/08/30 17:06:51 | I [g.IgnitionProjectManager ] [17:06:51.013]: Setting LastModification to "external" on Ignition_Training/Model [productiongateway/model]
INFO | jvm 1 | 2024/08/30 17:06:51 | I [Project ] [17:06:51.179]: Restarting gateway scripts... project=Ignition_Training
INFO | jvm 1 | 2024/08/30 17:14:26 | W [ClockDriftDetector ] [17:14:23.577]: Clock drift, degraded performance, or pause-the-world detected.
INFO | jvm 1 | 2024/08/30 17:14:26 | Max allowed deviation=1000ms, actual deviation=2622ms
INFO | jvm 1 | 2024/08/30 17:14:26 | W [ClockDriftDetector ] [17:14:26.323]: Clock drift, degraded performance, or pause-the-world detected.
INFO | jvm 1 | 2024/08/30 17:14:26 | Max allowed deviation=1000ms, actual deviation=1746ms
INFO | jvm 1 | 2024/08/30 17:22:54 | W [ClockDriftDetector ] [17:22:54.476]: Clock drift, degraded performance, or pause-the-world detected.
INFO | jvm 1 | 2024/08/30 17:22:54 | Max allowed deviation=1000ms, actual deviation=1382ms
INFO | jvm 1 | 2024/08/30 17:24:26 | I [P.InternalDatabase ] [17:24:26.560]: Creating auto-backup of internal database "config.idb"...
INFO | jvm 1 | 2024/08/30 17:24:26 | I [P.InternalDatabase ] [17:24:26.660]: Created auto-backup of internal database "config.idb" in 100 ms
STATUS | wrapper | 2024/08/30 17:40:47 | JVM appears hung: Timed out waiting for signal from JVM. Restarting JVM.
ERROR | wrapper | 2024/08/30 17:41:02 | Timed out waiting for the OS to forcibly terminate the JVM process, unable to continue.
ERROR | wrapper | 2024/08/30 17:41:02 | The scheduled restart of the JVM has been cancelled.
STATUS | wrapper | 2024/08/30 17:41:54 | <-- Wrapper Stopped
Not enough info, need more logs.
Also you should contact support ![]()
This might point to your gateway not having enough resrouces, or one of your scripts to be taking up to much resources. or a connection to a something being slowed down by something
