I am running Ignition 7.5.3-linux-x64 on Ubuntu 12.04.1-server-amd64 kernel 3.2.0-29-generic.
java version “1.6.0_24”
OpenJDK Runtime Environment (IcedTea6 1.11.3) (6b24-1.11.3-1ubuntu0.12.04.1)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
I am having two problems, the first causing the second.
First off, Ignition is losing connectivity w/ my Modbus devices. It looks like this is a PLC problem, because when I sniff the network I see the PLC sending a TCP RST. In Ignition logs I get:
82750-INFO | jvm 3 | 2012/10/28 00:35:29 | ERROR [SocketIODelegate ] [00:35:29,215]: [hostname=192.168.1.58,port=502] Socket connection closed, DriverState was Connected.
82751-INFO | jvm 3 | 2012/10/28 00:35:29 | java.net.SocketException: Connection reset
82752-INFO | jvm 3 | 2012/10/28 00:35:29 | at java.net.SocketInputStream.read(SocketInputStream.java:185)
82753-INFO | jvm 3 | 2012/10/28 00:35:29 | at java.net.SocketInputStream.read(SocketInputStream.java:107)
82754-INFO | jvm 3 | 2012/10/28 00:35:29 | at com.inductiveautomation.common.iosession.socket.AsyncSocketIOSession.run(AsyncSocketIOSession.java:92)
82755-INFO | jvm 3 | 2012/10/28 00:35:29 | at java.lang.Thread.run(Thread.java:679)
I am directly on the network, no routers or firewalls between. We can blame our equipment for now. The issue is this leads to the Ignition server not responding.
I get
82756-INFO | jvm 3 | 2012/10/28 00:35:33 | ERROR [ModbusDriver2[PLC12B] ] [00:35:33,700]: Error during connect.
82757:INFO | jvm 3 | 2012/10/28 00:35:33 | java.net.SocketException: Too many open files
82758-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.net.Socket.createImpl(Socket.java:414)
82759-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.net.Socket.connect(Socket.java:544)
82760-INFO | jvm 3 | 2012/10/28 00:35:33 | at com.inductiveautomation.xopc.driver.api.SocketIODelegate.connect(SocketIODelegate.java:75)
82761-INFO | jvm 3 | 2012/10/28 00:35:33 | at com.inductiveautomation.xopc.driver.api.AbstractIODelegatingDriver.connect(AbstractIODelegatingDriver.java:17)
82762-INFO | jvm 3 | 2012/10/28 00:35:33 | at com.inductiveautomation.xopc.driver.api.AbstractDriver$5.run(AbstractDriver.java:481)
82763-INFO | jvm 3 | 2012/10/28 00:35:33 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
82764-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
82765-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
82766-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.util.concurrent.FutureTask.run(FutureTask.java:166)
82767-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(ScheduledThreadPoolExecutor.java:165)
82768-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:266)
82769-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
82770-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
82771-INFO | jvm 3 | 2012/10/28 00:35:33 | at java.lang.Thread.run(Thread.java:679)
in my logs. Checking lsof on the Ignition process I get hundreds of line of:
java 2511 ignition 4065u sock 0,7 0t0 17076417 can't identify protocol
java 2511 ignition 4066u sock 0,7 0t0 17076418 can't identify protocol
java 2511 ignition 4067u sock 0,7 0t0 17076425 can't identify protocol
java 2511 ignition 4068u sock 0,7 0t0 17076507 can't identify protocol
java 2511 ignition 4069u sock 0,7 0t0 17076636 can't identify protocol
java 2511 ignition 4070u sock 0,7 0t0 17076488 can't identify protocol
java 2511 ignition 4071u sock 0,7 0t0 17076497 can't identify protocol
java 2511 ignition 4072u sock 0,7 0t0 17076498 can't identify protocol
Any thoughts on why when the connection gets reset does Ignition/Java not clean up?
