I have the following query which runs fine in MSSQL Management Studio, but will not even let me accept the query in Ignition.
Select COALESCE(CAST
(CASE WHEN (DatePart(mi,max(t_stamp) - min(t_stamp))) <= 0 THEN 0 ELSE (max(Good_Bags)-min(Good_Bags)) / cast((DatePart(mi,max(t_stamp) - min(t_stamp)))as decimal(4,1)) END AS DECIMAL(4,1)),0) as "BPM"
FROM BagCount
WHERE EquipID like '%MET_02' and
t_stamp > DateAdd(mi,-5,GetDate()) and
GOOD_BAGS > 0
Any Ideas? I will need to replace the hard coded EquipID with a Tag, but I can handle that if the query will run otherwise.
Are you using this query in a script or in binding? If you are using it in scripting you need to escape the % in the like clause with another % only if you are doing string formatting using %s or %d. You also want to make sure you escape the single or double quotes depending on what you are using for the string.
I am trying to create a new SQL Tag based on this query. Can you show me what the escaped query would look like? I haven’t used that function before and seem to be struggling with the syntax. I think the help file assumes I am smarter that I really am.
Oh, in that case you need to make sure your db connection is the default for the SQLTags provider. You can check this in the gateway config section under SQLTags Providers -> Realtime by editing your provider.
