I just started a Amazon AWS free 30 trial and thought I’d try Ignition Maker on it. I used the AWS Lightsail with LAMP since I figured I could save the MySQL install step.
Starting the Gateway gave an unusual error:
java.base/java.lang.Thread.run(Thread.java:834)
java.lang.Exception: Java process exec failed with error code 1: Job for Ignition-Gateway.service failed because the control process exited with error code. See “systemctl status Ignition-Gateway.service” and “journalctl -xe” for details.
However if I stopped the mysql service, the Gateway start would be fine. If I started mysql after that the Gateway would do a hard crash. Seems gone from memory. If I stopped mysql, I could restart the Gateway OK. This is on the “free for 30 days” 512 MB Lightsail LAMP instance.
I do have the Ignition maker running now. I created (copied) a new instance of the LAMP server. I run mysql on one and the Gateway on the other. Anyone else ever try to install on a memory constrained system like this?
If you run this, what's the output? If you're using default values, then I believe the gateway's asking for more than 512mB of memory. You could try changing the max memory config in /data/ignition.conf.
However, even if you get it running, you're going to have a hard time doing much of anything on a system with 512mB of memory; both Ignition and MySQL tend to be memory-hungry processes. If you're just looking to use basic historian/etc features, newer 8.0 versions have an "Internal" historian type available that uses a SQLite database on disk next to Ignition - much lighter weight than a full MySQL instance.
