Hello,
trying to update a tank to a new number. Going through the params and renaming folders. All folders renamed successfully except one. and i get the below error:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 60001
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:327)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:297)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:258)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:884)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager.editTags(DatasourceTagManager.java:373)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.editTags(ClientTagManagerImpl.java:398)
at com.inductiveautomation.ignition.designer.sqltags.util.TagUtilities.modifyTagProperty(TagUtilities.java:102)
at com.inductiveautomation.ignition.designer.sqltags.search.SQLTagTreeModelImpl.valueForPathChanged(SQLTagTreeModelImpl.java:169)
at javax.swing.plaf.basic.BasicTreeUI.completeEditing(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.editingStopped(Unknown Source)
at javax.swing.AbstractCellEditor.fireEditingStopped(Unknown Source)
at javax.swing.DefaultCellEditor$EditorDelegate.stopCellEditing(Unknown Source)
at javax.swing.DefaultCellEditor.stopCellEditing(Unknown Source)
at javax.swing.DefaultCellEditor$EditorDelegate.actionPerformed(Unknown Source)
at javax.swing.JTextField.fireActionPerformed(Unknown Source)
at javax.swing.JTextField.postActionEvent(Unknown Source)
at javax.swing.JTextField$NotifyAction.actionPerformed(Unknown Source)
at javax.swing.SwingUtilities.notifyAction(Unknown Source)
at javax.swing.JComponent.processKeyBinding(Unknown Source)
at javax.swing.JComponent.processKeyBindings(Unknown Source)
at javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: java.lang.NullPointerException
com.inductiveautomation.ignition.common.GenericTransferrableException
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.modifyTag(InternalTagStore.java:838)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.modifyTags(InternalTagStore.java:792)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.renameFolder(AbstractStoreBasedTagProvider.java:957)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.editTags(AbstractStoreBasedTagProvider.java:870)
at com.inductiveautomation.ignition.gateway.sqltags.providers.RedundantProviderWrapper._editTags(RedundantProviderWrapper.java:79)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.inductiveautomation.ignition.common.messages.ReflectiveInvokeMessage.execute(ReflectiveInvokeMessage.java:41)
at com.inductiveautomation.ignition.gateway.sqltags.providers.RedundantProviderWrapper$ConfigRedundancyMessageListener.receiveCall(RedundantProviderWrapper.java:196)
at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:45)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:739)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:760)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:537)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Ignition v7.8.5 (b2016120813)
Java: Oracle Corporation 1.8.0_271
