I have some Gateway events, based on tag changes that run some script code. They are calling some functions from a library that is in a project that is inherited, in case that may factor in.
I am having a problem where I have some functions that seem to be running 'twice' when I get the tag change event. I have troubleshot and am not getting the OPC/plc signal twice, or multiple times.
As you can see on the first screen shot, most of them are disabled. I have enabled the ones I need for testing here in production. Even when disabled, the code in the tag change event highlighted here is still running. When enabling it, then I get the results twice.
I have several projects in this gateway, that are mostly vision/HMI projects, and these gateway tag event scripts exist on one of them. I have scoured all the rest of the projects, as well as for client tag events to see if I have errantly put these elsewhere in testing, and I can find nothing.
Is there some other troubleshooting I can do to find where this script code might be running from, when I have the tag event scripts disabled? Thanks.
