I am not sure why this is not executing properly.
I am looking to set a tag value when  minute == 00.
Eventually I will be setting it at 12:01 am to reset some PLC tag values.
I have been trying to use the Gateway event script with a "Setting "of: 00 Minutes.
The Script is:
def onScheduledEvent():
	meterresets = ["[default]Timetags/ResetMeters"]
	values = [0]
	system.tag.writeAsync(meterresets,values);
	print 'completed'
Is there something missing ??
              Is the scheduled script enabled and what is your configuration for when it is supposed to run?
              “Not executing properly” is very ambiguous; does the code not execute, or is there an error logged? We need to know what the incorrect behavior is before we can really provide insight into how to fix it.
              I believe I found the issue.
The incorrect project was referenced in the Gateway Settings under the “Gateway Scripting Project” field.
Once that way corrected, the script started working properly.
Thanks for your responses.
Another “Loose Nut at the Terminal” issue
              Got similar issue with scheduled gateway scripts not running. Gateway setting are correct. Scripting is correct and tested on another project.
              You're gonna have to give us more details, we can't fix something we know nothing about.
Show us the script (see how to post code) and the configuration of the event.
If there are errors in the logs, show them too.
