Gateway event script running a named update query
Hi Guys,
I can't get a timer (every 5 seconds) gateway event script that runs a named update query to work.
If I run the same code on a button it works as expected...
Any assistance would be appreciated.
Named Query:
INSERT INTO test (id) VALUES (:id)
Timer Gateway Event Script:
id = "test"
params = {"id":id}
system.db.runNamedQuery("test", params)
Error:
Traceback (most recent call last): File "<TimerScript:Weather/test @5,000ms >", line 3, in <module> at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.runNamedQuery(GatewayDBUtilities.java:354) at sun.reflect.GeneratedMethodAccessor95.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) java.lang.NullPointerException: java.lang.NullPointerException
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 3, in at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.runNamedQuery(GatewayDBUtilities.java:354) at sun.reflect.GeneratedMethodAccessor95.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) java.lang.NullPointerException: java.lang.NullPointerException
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.Py.JavaError(Py.java:488)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:431)
at org.python.core.PyObject.call(PyObject.java:404)
at org.python.core.PyObject.call(PyObject.java:408)
at org.python.pycode._pyx17.f$0(:3)
at org.python.pycode._pyx17.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:636)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:603)
at com.inductiveautomation.ignition.common.script.TimerScriptTask.run(TimerScriptTask.java:88)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
Caused by: org.python.core.PyException: Traceback (most recent call last): File "", line 3, in at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.runNamedQuery(GatewayDBUtilities.java:354) at sun.reflect.GeneratedMethodAccessor95.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) java.lang.NullPointerException: java.lang.NullPointerException
... 16 common frames omitted
Caused by: java.lang.NullPointerException: null
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
As soon as I post I figure it out...
Needed to change:
system.db.runNamedQuery(“test”, params)
To:
system.db.runNamedQuery("Project Name", “test”, params)
