Does anyone know what would cause the gateway event scripts window to open with all the events missing? This has happened numerous times and the only way I found to fix it is to re-open the project.
This kind of thing happens to me when I am working over a weak connection or VPN.
The issue with mine is happening randomly with a good connection..
I had to minimize the designer to jump into another app and when I went back into the designer (about 2 minutes later) the gateway events was blank again.
My concern is that if the event window is blank and I click save (because of other changes in the designer I've made), will it erase the tag change events I had in the project?
