我通过button onclick运行system.perspective.sendMessage("mapRefresh",payload = {}, scope = "session") 是成功(is ok)的.
I want Periodic refresh sendMessage刷新数据, 但是在Gateway Event Timer 中运行代码则不成效(inoperative).
不知道是什么原因, 请帮助我一下. 谢谢!
Please post your full code as pre-formatted text.
I suspect one reason your 2nd image code isn't working is because it needs indented one tab. An onClick Mouse Event on a button is a function so at the top there will be:
def():
#put your code here
where you have done:
def():
#your code is here
You can't use system.perspective.sendMessage() outside of Perspective scripts. Gateway events are outside of Perspective. You must use system.util.sendMessage(...., scope='S') to deliver to a perspective session message handler, which can then relay with system.perspective.sendMessage() to the actual perspective scope you wish to target (if not session).
See this discussion:
谢谢您的回复, 我经过测试不是由于缩进的原因导致的.
You've put a function in a function. Your def getHostInfo needs indented after def onMessageReceived
