Hello,
I am getting this error on one named query only:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to read response from Gateway.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:500)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)
at com.inductiveautomation.ignition.designer.db.namedquery.workspace.NamedQueryTestingPanel$1$1.doInBackground(NamedQueryTestingPanel.java:369)
at com.inductiveautomation.ignition.designer.db.namedquery.workspace.NamedQueryTestingPanel$1$1.doInBackground(NamedQueryTestingPanel.java:344)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: org.xml.sax.SAXParseException; lineNumber: 4; columnNumber: 16; Element type "column" must be followed by either attribute specifications, ">" or "/>".
at java.xml/com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:498)
... 11 more
Ignition v8.1.31 (b2023081007)
Java: Azul Systems, Inc. 11.0.18
The query is a basic select * from table, 254 rows. If I use the DB query browser, I see the results just fine. The origins of this table is this: MySql source, exported to csv file, imported into SQL Server into new table, default data types.
Just previous to this error, this particular schema did not have a User Select Permission, which I got an appropriate error for. After applying said permission, this is the error.
Thoughts?
Edit:
Just discovered this looking at a select query run in SSMS:
