Windows 7 Pro SP1
Java: v8b25 (build 1.8.0_25-b18)
Ignition 7.7.1 (b2014092209) | 64-bit
Clicking the [Restart] button on the GCU stops the gateway but it fails to restart.
After that, clicking the triangular green ‘start’ icon does start it up again.
I note this bug was also reported on an earlier version https://www.inductiveautomation.com/forum/viewtopic.php?f=72&t=11008&p=39277&hilit=restart+gateway+control+utility#p39277.
This snip of the wrapper log I think reflects the stop and restart attempt (12:12) then the “Start” after waiting 10 minutes at 12:22
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [SRContext ] [12:12:29,496]: Platform module services uninitialized.
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [MulticastScheduler ] [12:12:29,497]: MulticastScheduler shutting down.
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [FallbackSocketController ] [12:12:29,497]: Fallback Socket Controller shutting down.
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [SRContext ] [12:12:29,497]: Ignition Gateway shut down in 6987ms
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [SRContext ] [12:12:29,497]: Ignition["/main", state=STOPPING] ContextState = STOPPED
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [BasicExecutionEngine ] [12:12:29,497]: Execution engine ‘TagSubscriptionModel’ shut down in 0ms
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [BasicExecutionEngine ] [12:12:29,497]: Execution engine ‘TagEventScriptDispatch’ shut down in 0ms
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [BasicExecutionEngine ] [12:12:29,497]: Execution engine ‘fsql’ shut down in 0ms
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [BasicExecutionEngine ] [12:12:29,497]: Execution engine ‘ExecEngine-1’ shut down in 0ms
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [Application ] [12:12:29,498]: [WicketFilter] destroy: Wicket core library initializer
INFO | jvm 1 | 2014/12/12 12:12:29 | INFO [Application ] [12:12:29,498]: [WicketFilter] destroy: Wicket extensions initializer
INFO | jvm 1 | 2014/12/12 12:12:29 | 2014-12-12 12:12:29.509:INFO:oejsh.ContextHandler:Thread-432: Stopped o.e.j.w.WebAppContext@6125ef0e{/main,file:/C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/,UNAVAILABLE}
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp:
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: Encountered an error running main:
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: java.lang.IllegalStateException: Shutdown in progress
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at java.lang.ApplicationShutdownHooks.add(Unknown Source)
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at java.lang.Runtime.addShutdownHook(Unknown Source)
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:62)
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:290)
INFO | jvm 1 | 2014/12/12 12:12:29 | WrapperSimpleApp Error: at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2014/12/12 12:12:30 | Java HotSpot™ 64-Bit Server VM warning: ignoring option PermSize=64m; support was removed in 8.0
INFO | jvm 1 | 2014/12/12 12:12:30 | Java HotSpot™ 64-Bit Server VM warning: ignoring option MaxPermSize=128m; support was removed in 8.0
INFO | jvm 1 | 2014/12/12 12:12:30 | Please use CMSClassUnloadingEnabled in place of CMSPermGenSweepingEnabled in the future
STATUS | wrapper | 2014/12/12 12:12:31 | <-- Wrapper Stopped
STATUS | wrapper | 2014/12/12 12:22:38 | --> Wrapper Started as Service
STATUS | wrapper | 2014/12/12 12:22:38 | Java Service Wrapper Standard Edition 64-bit 3.5.15
STATUS | wrapper | 2014/12/12 12:22:38 | Copyright © 1999-2012 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2014/12/12 12:22:38 | wrapper.tanukisoftware.com
STATUS | wrapper | 2014/12/12 12:22:38 | Licensed to Inductive Automation for Ignition Gateway
STATUS | wrapper | 2014/12/12 12:22:38 | Launching a JVM…
INFO | jvm 1 | 2014/12/12 12:22:38 | WrapperManager: Initializing…
INFO | jvm 1 | 2014/12/12 12:22:39 | 2014-12-12 12:22:39.423:INFO:oejs.Server:WrapperSimpleAppMain: jetty-9.1.z-SNAPSHOT
INFO | jvm 1 | 2014/12/12 12:22:40 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2014/12/12 12:22:41 | 2014-12-12 12:22:41.145:INFO:oejw.StandardDescriptorProcessor:WrapperSimpleAppMain: NO JSP Support for /main, did not find org.apache.jasper.servlet.JspServlet
INFO | jvm 1 | 2014/12/12 12:22:41 | INFO [SRClassLoader ] [12:22:41,330]: SRClassLoader init
INFO | jvm 1 | 2014/12/12 12:22:43 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2014/12/12 12:22:44 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2014/12/12 12:22:45 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2014/12/12 12:22:46 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2014/12/12 12:22:48 | Uncaught exception during getContextState():java.lang.NullPointerException
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [Application ] [12:22:48,686]: [WicketFilter] init: Wicket core library initializer
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [RequestListenerInterface ] [12:22:48,689]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [RequestListenerInterface ] [12:22:48,689]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [RequestListenerInterface ] [12:22:48,690]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [RequestListenerInterface ] [12:22:48,690]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [RequestListenerInterface ] [12:22:48,690]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [RequestListenerInterface ] [12:22:48,691]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [Application ] [12:22:48,691]: [WicketFilter] init: Wicket extensions initializer
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [SRContext ] [12:22:48,711]: Ignition["/main", state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [SRContext ] [12:22:48,731]: Starting Ignition 7.7.1 (b2014092209)
INFO | jvm 1 | 2014/12/12 12:22:48 | INFO [SRContext ] [12:22:48,732]: Reloading JDBC classloader.
INFO | jvm 1 | 2014/12/12 12:22:50 | INFO [SecureRandomProvider ] [12:22:50,323]: Creating SecureRandom object…
INFO | jvm 1 | 2014/12/12 12:22:50 | INFO [SecureRandomProvider ] [12:22:50,326]: … SecureRandom Created.
INFO | jvm 1 | 2014/12/12 12:22:50 | INFO [SecureRandomProvider ] [12:22:50,371]: Secure random seed generated in 1ms
INFO | jvm 1 | 2014/12/12 12:22:50 | INFO [WebApplication ] [12:22:50,430]: [WicketFilter] Started Wicket version 6.1.1 in DEPLOYMENT mode
INFO | jvm 1 | 2014/12/12 12:22:50 | 2014-12-12 12:22:50.436:INFO:oejsh.ContextHandler:WrapperSimpleAppMain: Started o.e.j.w.WebAppContext@54d46cfb{/main,file:/C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/,AVAILABLE}
INFO | jvm 1 | 2014/12/12 12:22:50 | INFO [StateMonitoring ] [12:22:50,467]: The redundant node state has changed. Current state: [RedundancyState[role=Independent, activity level=Active, project state=Good, history level=Full]
INFO | jvm 1 | 2014/12/12 12:22:50 | 2014-12-12 12:22:50.629:INFO:oejs.ServerConnector:WrapperSimpleAppMain: Started ServerConnector@46ad9c25{HTTP/1.1}{0.0.0.0:8088}
INFO | jvm 1 | 2014/12/12 12:22:51 | 2014-12-12 12:22:51.203:INFO:oejs.ServerConnector:WrapperSimpleAppMain: Started ServerConnector@629beb3{SSL-HTTP/1.1}{0.0.0.0:8043}
INFO | jvm 1 | 2014/12/12 12:22:55 | WARN [ModuleManager ] [12:22:55,090]: Could not read license from HASP key. HASP login() failed. Last error = 14.
INFO | jvm 1 | 2014/12/12 12:22:55 | INFO [ModuleManager ] [12:22:55,092]: Loading modules…
