Getting this error when starting up a gateway and it stops right after… Not sure where to go with this one!
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp:
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: Encountered an error running main:
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: MultiException[java.io.IOException: Invalid keystore format, java.io.IOException: Invalid keystore format]
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.server.Server.doStart(Server.java:347)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Jetpad.start(Jetpad.java:370)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.start(Catapult.java:140)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at com.inductiveautomation.catapult.Catapult.main(Catapult.java:62)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: Suppressed: java.io.IOException: Invalid keystore format
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at sun.security.provider.JavaKeyStore.engineLoad(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at sun.security.provider.JavaKeyStore$JKS.engineLoad(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at sun.security.provider.KeyStoreDelegator.engineLoad(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at sun.security.provider.JavaKeyStore$DualFormatJKS.engineLoad(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at java.security.KeyStore.load(Unknown Source)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.util.security.CertificateUtils.getKeyStore(CertificateUtils.java:52)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.util.ssl.SslContextFactory.loadKeyStore(SslContextFactory.java:1016)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.util.ssl.SslContextFactory.doStart(SslContextFactory.java:332)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.server.SslConnectionFactory.doStart(SslConnectionFactory.java:64)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:260)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:81)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:244)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: at org.eclipse.jetty.server.Server.doStart(Server.java:384)
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: ... 10 more
INFO | jvm 1 | 2022/06/09 10:54:28 | WrapperSimpleApp Error: Caused by: java.io.IOException: Invalid keystore format
INFO | jvm 1 | 2022/06/09 10:54:28 | I [g.InternalDatabaseManager ] [01:24:28]: Starting up...
INFO | jvm 1 | 2022/06/09 10:54:28 | I [P.InternalDatabase ] [01:24:28]: Looking for existing internal database "config.idb"...
INFO | jvm 1 | 2022/06/09 10:54:28 | I [P.InternalDatabase ] [01:24:28]: ... found existing.
INFO | jvm 1 | 2022/06/09 10:54:28 | I [P.InternalDatabase ] [01:24:28]: internal database "config.idb" started up successfully.
INFO | jvm 1 | 2022/06/09 10:54:28 | I [P.InternalDatabase ] [01:24:28]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database "config.idb"]
INFO | jvm 1 | 2022/06/09 10:54:28 | I [g.ModuleManager ] [01:24:28]: Loading modules....
INFO | jvm 1 | 2022/06/09 10:54:29 | I [A.Notification ] [01:24:29]: Alert notification system created.
STATUS | wrapper | 2022/06/09 10:54:31 | <-- Wrapper Stopped
