Hi All,
I’m getting a “Ignition Gateway is FAULTED” message after restarting the gateway. Any help would be appreciated.
This is the end of the wrapper log file, but i can’t make much sense of it:
INFO | jvm 3 | 2021/10/25 21:15:32 | E [IgnitionGateway ] [01:15:32]: Error during context startup.
INFO | jvm 3 | 2021/10/25 21:15:32 | java.lang.NullPointerException: null
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.io.ByteArrayInputStream.(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:248)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor.lambda$initializeQueries$0(NamedQueryExecutor.java:96)
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.util.ArrayList.forEach(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor.initializeQueries(NamedQueryExecutor.java:92)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor.initializeQueries(NamedQueryExecutor.java:82)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor.(NamedQueryExecutor.java:76)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.db.namedquery.GatewayNamedQueryManager$NamedQueryLifeCycle.onStartup(GatewayNamedQueryManager.java:326)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycle.onStartup(ProjectLifecycle.java:38)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.common.lifecycle.AbstractLifecycle.startup(AbstractLifecycle.java:18)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.maybeStartLifecycle(ProjectLifecycleFactory.java:234)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.lambda$projectAdded$0(ProjectLifecycleFactory.java:124)
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.util.Optional.ifPresent(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.projectAdded(ProjectLifecycleFactory.java:124)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory.onStartup(ProjectLifecycleFactory.java:47)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.db.namedquery.GatewayNamedQueryManager.onStartup(GatewayNamedQueryManager.java:57)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1113)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:293)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:724)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:658)
INFO | jvm 3 | 2021/10/25 21:15:32 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:538)
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | at java.base/java.lang.Thread.run(Unknown Source)
INFO | jvm 3 | 2021/10/25 21:15:32 | I [IgnitionGateway ] [01:15:32]: Ignition[state=STARTING] ContextState = FAULTED
