Gateway Faulted - Attempt to write to read only database
Hello, I previously had a ignition gateway running on a raspberry pi 4b. Opon a restart of the pi I get this error when trying to start the gateway. I'm very new to Linux so any help on how to resolve this would be appreciated!
INFO   | jvm 1    | 2023/05/05 15:22:10 | 15:22:10,273 |-ERROR in com.inductiveautomation.logging.SQLiteAppender[DB] - problem appending event org.sqlite.SQLiteException: [SQLITE_READONLY] Attempt to write a readonly database (attempt to write a readonly database)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at org.sqlite.SQLiteException: [SQLITE_READONLY] Attempt to write a readonly database (attempt to write a readonly database)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at org.sqlite.core.DB.newSQLException(DB.java:1141)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at org.sqlite.core.DB.newSQLException(DB.java:1152)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at org.sqlite.core.DB.execute(DB.java:950)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at org.sqlite.core.DB.executeUpdate(DB.java:1016)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at org.sqlite.jdbc3.JDBC3PreparedStatement.executeUpdate(JDBC3PreparedStatement.java:90)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at com.inductiveautomation.logging.SQLiteAppender.subAppend(SQLiteAppender.java:564)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at com.inductiveautomation.logging.SQLiteAppender.batchAppend(SQLiteAppender.java:503)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 1    | 2023/05/05 15:22:10 | 	at 	at java.base/java.lang.Thread.run(Unknown Source)
That looks like a folder permissions issue. Like the prior install was set to run as root, and the current install is set to run as an unprivileged (or less-privileged) user. The latter is wise, but can take some extra setup (or a completely clean install with the service user parameter set).
