Gateway faulted but web server started
I am trying to set a new install of Igniton 7.6.4 and the gateway will not start. here is what i see in the wrapper file
[quote]INFO | jvm 2 | 2014/01/17 09:49:55 | ERROR [PersistenceInterface ] [09:49:55,095]: Error saving record: “[SystemPropertiesRecord 0 NewRecord Dirty0]”
INFO | jvm 2 | 2014/01/17 09:49:55 | simpleorm.utils.SException$Validation: Field [F SystemPropertiesRecord.SystemAuthProfileId] must be NOT NULL
INFO | jvm 2 | 2014/01/17 09:49:55 | at simpleorm.dataset.validation.SValidatorNotNull.onValidate(SValidatorNotNull.java:15)
INFO | jvm 2 | 2014/01/17 09:49:55 | at simpleorm.dataset.SFieldMeta.doValidate(SFieldMeta.java:277)
INFO | jvm 2 | 2014/01/17 09:49:55 | at simpleorm.dataset.SRecordInstance.doValidateRecord(SRecordInstance.java:903)
INFO | jvm 2 | 2014/01/17 09:49:55 | at simpleorm.sessionjdbc.SSessionJdbcHelper.flush(SSessionJdbcHelper.java:264)
INFO | jvm 2 | 2014/01/17 09:49:55 | at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:425)
INFO | jvm 2 | 2014/01/17 09:49:55 | at simpleorm.sessionjdbc.SSessionJdbc.flush(SSessionJdbc.java:410)
INFO | jvm 2 | 2014/01/17 09:49:55 | at simpleorm.sessionjdbc.SSessionJdbc.commitAndDetachDataSet(SSessionJdbc.java:351)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.save(PersistenceInterfaceImpl.java:108)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl.ensureRecordExists(LocalDBManagerImpl.java:229)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.gateway.authentication.UserSourceManagerImpl.setup(UserSourceManagerImpl.java:125)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:1072)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:183)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:871)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.gateway.SRContext.access$200(SRContext.java:211)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:603)
INFO | jvm 2 | 2014/01/17 09:49:55 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.util.concurrent.FutureTask.run(FutureTask.java:166)
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178)
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292)
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.lang.Thread.run(Thread.java:724)
INFO | jvm 2 | 2014/01/17 09:49:55 | ERROR [SRContext ] [09:49:55,097]: Error during context startup.
INFO | jvm 2 | 2014/01/17 09:49:55 | at java.lang.Thread.run(Thread.java:724)[/quote]
