Gateway Faulted. Won’t start
Gateway Faulted on restart and won’t start.
wrapper.txt (9.5 MB)
Did you run out of disk space on the server (that you're running the DB on :grimacing:)?
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Could not allocate a new page for database 'ns30cell_general' because the 'PRIMARY' filegroup is full due to lack of storage space or database files reaching the maximum allowed size. Note that UNLIMITED files are still limited to 16TB. Create the necessary space by dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.
Also, you should really contact the support department officially if you need any urgent support.
I appreciate your help so quickly. I threw this up here as a shot in the dark while I was running some other checks and contacting IT. I was able to stop and start the Gateway and it did come back up without faulting. I’ll be looking at the DB Server and your other information above.
