Hi
I have recently updated Ignition (running under Mac OSX) to the latest version. Following this, the gateway fails to start (the webpage simply shows the “Gateway Faulted” message). I have been unable to find any other references on this forum to this error (java.lang.NoSuchMethodError), so hopefully I am not repeating a common issue! However, here is the last few lines of the wrapper.log file showing the failure.
INFO | jvm 1 | 2012/10/18 22:09:30 | ERROR [SRContext ] [22:09:30,477]: Error during context startup.
INFO | jvm 1 | 2012/10/18 22:09:30 | java.lang.NoSuchMethodError: org.python.core.PyReflectedFunction.<init>([Ljava/lang/reflect/Method;)V
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.common.script.ScriptManager.addScriptModule(ScriptManager.java:297)
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.common.script.ScriptManager.<init>(ScriptManager.java:112)
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.gateway.SRContext.createScriptManager(SRContext.java:1054)
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.gateway.SRContext.startupInternal(SRContext.java:949)
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:184)
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.gateway.SRContext.asyncInit(SRContext.java:766)
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.gateway.SRContext.access$200(SRContext.java:191)
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.gateway.SRContext$2.run(SRContext.java:557)
INFO | jvm 1 | 2012/10/18 22:09:30 | at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
INFO | jvm 1 | 2012/10/18 22:09:30 | at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
INFO | jvm 1 | 2012/10/18 22:09:30 | at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
INFO | jvm 1 | 2012/10/18 22:09:30 | at java.util.concurrent.FutureTask.run(FutureTask.java:138)
INFO | jvm 1 | 2012/10/18 22:09:30 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:98)
INFO | jvm 1 | 2012/10/18 22:09:30 | at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:206)
INFO | jvm 1 | 2012/10/18 22:09:30 | at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
INFO | jvm 1 | 2012/10/18 22:09:30 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
INFO | jvm 1 | 2012/10/18 22:09:30 | at java.lang.Thread.run(Thread.java:680)
INFO | jvm 1 | 2012/10/18 22:09:30 | INFO [SRContext ] [22:09:30,478]: Ignition["/main", state=STARTING] ContextState = FAULTED
Any assistance in getting this rectified would be greatly appreciated.
Cheers
James
