Gateway keeps restarting
My inhouse gateway keeps restarting. Not sure why.
I have attached the wrapper log file
Uploading: wrapper.log…
Doesn't look like your log file uploaded successfully. Try zipping it first?
wrapper.zip (450.4 KB)
There you go, Thanks
It's freezing up and being restarted by the service wrapper for some reason.
Often this can be due to run away memory usage from, e.g. a historical query that is pulling back way too much data, or a bad script, or any number of things, really...
You'll probably have to work with support to track it down if you can't do it on your own. There's a history-related error in the logs each time before it restarts, but that could be coincidence.
