Gateway log flooded with StoreAndForward.Sink.HsqlDataStore Errors
My gateway log is flooded with these errors and I cannot find what is causing them.
Error deserializing data from data store.
java.lang.ClassCastException: cannot assign instance of com.inductiveautomation.ignition.common.sqltags.model.types.DataQuality to field com.inductiveautomation.ignition.common.model.values.BasicQualifiedValue.quality of type com.inductiveautomation.ignition.common.model.values.QualityCode in instance of com.inductiveautomation.ignition.common.model.values.BasicQualifiedValue
at java.base/java.io.ObjectStreamClass$FieldReflector.setObjFieldValues(Unknown Source)
at java.base/java.io.ObjectStreamClass$FieldReflector.checkObjectFieldValueTypes(Unknown Source)
at java.base/java.io.ObjectStreamClass.checkObjFieldValueTypes(Unknown Source)
at java.base/java.io.ObjectInputStream.defaultCheckFieldValues(Unknown Source)
at java.base/java.io.ObjectInputStream.readSerialData(Unknown Source)
at java.base/java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject0(Unknown Source)
at java.base/java.io.ObjectInputStream.defaultReadFields(Unknown Source)
at java.base/java.io.ObjectInputStream.readObject(Unknown Source)
at java.base/java.util.ArrayList.readObject(Unknown Source)
at java.base/jdk.internal.reflect.GeneratedMethodAccessor14.invoke(Unknown Source)
at java.base/java.io.ObjectStreamClass.invokeReadObject(Unknown Source)
at com.inductiveautomation.ignition.gateway.cluster.ClusterUtil.deserializeObject(ClusterUtil.java:96)
at com.inductiveautomation.ignition.gateway.cluster.ClusterUtil.deserializeObject(ClusterUtil.java:56)
at com.inductiveautomation.ignition.gateway.cluster.ClusterUtil.unzipAndDeserializeObject(ClusterUtil.java:90)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractDatasourceStore.deserializeObject(AbstractDatasourceStore.java:497)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractDatasourceStore.loadTransactions(AbstractDatasourceStore.java:570)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractDatasourceStore.syncdTakeNext(AbstractDatasourceStore.java:513)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractStore.takeNext(AbstractStore.java:213)
at com.inductiveautomation.ignition.gateway.history.stores.MultiStageStore.syncdTakeNext(MultiStageStore.java:165)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.synchedTakeNext(ForwarderThread.java:200)
at com.inductiveautomation.ignition.gateway.history.forwarders.RedundancyAwareForwarder.synchedTakeNext(RedundancyAwareForwarder.java:68)
at com.inductiveautomation.ignition.gateway.history.forwarders.ForwarderThread.run(ForwarderThread.java:139)
Did you upgrade from v7.9 with data in the store & forward cache?
Yeah I bet there was a few sets in there, so dump it?
Yeah, all kinds of data types were refactored, and serialization doesn’t like that.
I’ll give that a try, thanks @pturmel
So I deleted all the quarantine records but it didn’t make a difference in my logs, still 100s errors every minute. Is there a better way for dumping the store and forward cache?
Not sure. Support could probably tell you which SQLite file to delete…
I had a similar problem where deleting quarantine records didn’t work. The steps in this post did fix the problem. It was a dev environment for me, so I wasn’t worried about loosing some data. That may be a consideration for you.
