Is there a place where users get logged when they startup a session? I couldn’t seem to find any.Thanks, Jake
If you enable auditing for the project, login and logout events will be logged:
https://docs.inductiveautomation.com/display/DOC81/Auditing+Actions+Reference#AuditingActionsReference-PerspectiveAuditingActions
So I think I have it done. In Security I have a profile setup for internal, I have the project Perspective audit enabled and set to that profile, but when I look at the logs it doesn’t seem to have any thing.Thanks, jake
Unless you’ve changed things from the default, simply launching a Perspective session isn’t actually a secured action; everything is unauthenticated. Auditing only kicks in once you change security levels or authorization, e.g. by logging in (or after logging in when you try to reach a page that requires authentication).
If you want to log even unauthenticated access to your Perspective page(s), then you’ll probably want a session startup script.
They are authorized connections. Also, this is odd, but everytime I try to get logs the date changes to days there wouldn’t be logs, not sure why.
Hard to debug without seeing exactly what you’re seeing, unfortunately. What are you using to view the audit logs? Can you show a screenshot?
You could try a table in Vision (with the audit log binding function type) to manually pass start/end time and other filters, or just run the system.util.queryAuditLog function manually.
Can you show the project properties where you’ve enabled auditing in your project?
Also, what happens if you try a much wider date range, e.g 12/1/2021 - 1/1/2022 or something?
Hm, seems like everything’s correct. I’m probably missing someething obvious; I’d recommend getting in touch with support at this point.
Sounds good, thx
Just a note: audit logs capture a lot more than just session info. The name “Sessions” for your audit log therefore might be a little deceptive
Yeah, the setup was odd with multiple audits, figured I could cull out what we wanted:).
