I am not able to login my ignition gateway by using my gateway credentials even I can't login in designer also. From morning it was working fine suddenly I am facing this issue
Make sure your user source is available, such as Active Directory.
If internal, you may have to follow this:
The Gateway Command-line Utility provides a list of commands you can use to perform specific functions in the Gateway. The Gateway Command-line Utility or gwcmd provides basic commands, such as resetting the main password, changing the Gateway's...
I have deleted my Gateway user by mistake now what to do
Log in as administrator and fix it.
If you've lost the administrator then ...
