Gateway Machine Specs
I am looking for general guidance on spec'ing a machine to run an Ignition gateway.
Recognizing that many factors impact gateway performance, are there certain factors (e.g. quantity of OPC tags) that are most important to consider when determining the necessary resources (i.e. CPU, RAM, storage)?
We are in the early stages of planning a large system (100k+ tags, 100+ OPC connections). Any help would be appreciated!
Slight adjustments in regards to perspective load on systems:
Thank you! This is just what I was looking for.
