Is it possible to create a database tag that can be logged and tells me which gateway system is acting as the master?
I have a gateway timer script that runs every 30 seconds or something
from java.net import InetAddress
nodename = InetAddress.getLocalHost().getHostName()
if nodename == 'SCDAPOL1':
system.tag.writeToTag('NodeName', nodename)
elif nodename == 'SCDAPOL2':
There is a system tag for this in 7.3.0, you can use this code:#assuming the master node is SCDAPOL1
master = system.tag.getTagValue("[System]Gateway/Redundancy/IsMaster")
if master:
system.tag.writeToTag('NodeName', 'SCDAPOL1')
else:
system.tag.writeToTag('NodeName', 'SCDAPOL2')Or better yet, just use an expression:if({[System]Gateway/Redundancy/IsMaster},"SCDAPOL1","SCDAPOL2")
Works great!
Thank you
