First things first.
Ignition version is 8.1.1
When a remote gateway messageHandler is called and an exception is generated, it seems that the handling between a python exception and a java exception is different. It maybe my lack of understanding though between the two.
If I have a two different messageHandlers in a remote gateway like so:
pythonException
return ValueError('This is an uncaught python exception')
and
javaException
import java.lang.Exception
raise java.lang.Exception('This is an uncaught java exception')
Then I call the pythonException as follows:
def onSuccess(message):
inProgress = False
if not inProgress:
inProgress = True
print 'onSuccess'
print message
print type(message)
def onError(message):
inProgress = False
if not inProgress:
inProgress = True
print 'onError'
print message
reqObj = system.util.sendRequestAsync(
project='TicketTrackSync',
messageHandler='pythonException',
remoteServer='ignition-esp_hcp_whi'
reqObj.onSuccess(onSuccess)
reqObj.onError(onError)
I end up getting the onSuccess call back:
>>> onSuccess
<type 'exceptions.ValueError'>
However if I call the javaException as follows:
inProgress = False
if not inProgress:
inProgress = True
print 'onSuccess'
print message
print type(message)
inProgress = False
if not inProgress:
inProgress = True
print 'onError'
print message
messageHandler='javaException',
I end up getting the onError call back:
>>> onError
java.lang.Exception: Gateway-side exception: java.lang.Exception: Remote exception: Traceback (most recent call last):
File "<MessageHandlerScript:TicketTrackSync/javaException >", line 12, in handleMessage
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.python.core.PyReflectedConstructor.constructProxy(PyReflectedConstructor.java:211)
java.lang.Exception: java.lang.Exception: This is an uncaught java exception
Is this by design? I’m sending data across to a remote gateway that MAY have issues with a database insert, and I want to make 100% sure that I can capture and report errors that occur. Right now I’m doubling up on the onSuccess and onError call back with checks on the message to make sure that I don’t miss an exception, but it feels like a python exception should also generate the onError rather than just the java one.
