Gateway network connection error on restored gateway with different port
Hello!
I had to restore a gateway from a backup version.
once restored I can use the gateway and projects without any problem but I do see on the gateway there is an error:
I changed the port from :8089 in the original gateway to :8080 in this one
The project works fine and I can keep working on it without any issues but this error appear on the gateway.
It also appear errors on the gateway scripts:
is there anything I can do to fix this error in the gateway?
What is the actual error in the gateway network status page?
More than likely you have duplicate certificates.
I would delete the connections on both the current gateway and whatever gateway you are connecting to, and then reestablish the connection.
Thanks @MMaynard
I deleted the gateway connection. For what I´ve seen I really didn´t need it, everything, the server gateway and my local designer gateway are working fine.
