Gateway network vision Window access
I am working with network gateway architectures spread across multiple networks (Still in design phase).
I know that tags and alarms are accessible across multiple gateways when connected as gateway network.
But is it possible to share the vision windows across multiple gateways…
You can’t share Vision windows on the fly. What you can do is use the EAM module to set up a task that sends a window to a remote gateway over the gateway network.
Thanks for the reply @mgross
