We have several machines that are clones of each other with the same IP addresses on the PLCs. To work around this, we have each machine connected to its own VLAN. On the OS that our gateway is running on (a VM in HyperV), we have multiple interfaces setup connecting to each of the VLANs with its own IP address. With that, we are utilizing the "Local Address" setting to point the gateway device connection to each specific interface for each machine.
We are working on setting up redundant gateways as we are becoming more reliant on Ignition. Trouble is, I cannot setup (or its not ideal) two gateway servers with interfaces that have the same IP address on the same network. On the backup gateway, I cannot configure a different "Local Address". What would be the best way to handle this?
