Ignition v: 8.1.1
Windows 10, 2016 Standard
Hello there,
We are facing this issue since last week that out Ignition production Gateway restarts automatically. Please see below today’s log details pulled after it was auto restarted…
INFO | jvm 4 | 2021/09/13 12:29:38 | [38154.932s][warning][os,thread] Attempt to allocate stack guard pages failed.
INFO | jvm 4 | 2021/09/13 12:29:38 | OpenJDK 64-Bit Server VM warning: Attempt to unguard stack red zone failed.
INFO | jvm 4 | 2021/09/13 12:29:38 | An unrecoverable stack overflow has occurred.
INFO | jvm 4 | 2021/09/13 12:29:38 | #
INFO | jvm 4 | 2021/09/13 12:29:38 | # A fatal error has been detected by the Java Runtime Environment:
INFO | jvm 4 | 2021/09/13 12:29:38 | # EXCEPTION_STACK_OVERFLOW (0xc00000fd) at pc=0x00007ffba800b223, pid=48856, tid=53232
INFO | jvm 4 | 2021/09/13 12:29:38 | # JRE version: OpenJDK Runtime Environment (Zulu11.39+16-SA) (11.0.7+10) (build 11.0.7+10-LTS)
INFO | jvm 4 | 2021/09/13 12:29:38 | # Java VM: OpenJDK 64-Bit Server VM (11.0.7+10-LTS, mixed mode, tiered, compressed oops, g1 gc, windows-amd64)
INFO | jvm 4 | 2021/09/13 12:29:38 | # Problematic frame:
INFO | jvm 4 | 2021/09/13 12:29:38 | # V [jvm.dll+0x35b223]
INFO | jvm 4 | 2021/09/13 12:29:38 | # Core dump will be written. Default location: C:\Program Files\Inductive Automation\Ignition\hs_err_pid48856.mdmp
INFO | jvm 4 | 2021/09/13 12:29:38 | # An error report file with more information is saved as:
INFO | jvm 4 | 2021/09/13 12:29:38 | # C:\Program Files\Inductive Automation\Ignition\hs_err_pid48856.log
INFO | jvm 4 | 2021/09/13 12:29:39 | [38156.088s][warning][os,thread] Failed to start thread - _beginthreadex failed (EINVAL) for attributes: stacksize: default, flags: CREATE_SUSPENDED STACK_SIZE_PARAM_IS.
INFO | jvm 4 | 2021/09/13 12:29:39 | W [d.S.B.TimeoutDaemon ] [06:59:37]: ScheduledRequest[com.inductiveautomation.xopc.drivers.siemens.requests.ReadRequest@13d33303] request with key "14061" failed due to timeout. device-name=PWV_S7_300
INFO | jvm 4 | 2021/09/13 12:29:39 | W [d.S.ReadRequest ] [06:59:37]: Request failed due to TIMEOUT device-name=PWV_S7_300
INFO | jvm 4 | 2021/09/13 12:29:39 | W [d.S.B.TimeoutDaemon ] [06:59:37]: ScheduledRequest[com.inductiveautomation.xopc.drivers.siemens.requests.ReadRequest@1261fc02] request with key "17597" failed due to timeout. device-name=Vehicle_Siement_PLC_300
INFO | jvm 4 | 2021/09/13 12:29:39 | W [d.S.ReadRequest ] [06:59:37]: Request failed due to TIMEOUT device-name=Vehicle_Siement_PLC_300
INFO | jvm 4 | 2021/09/13 12:29:39 | W [d.S.B.TimeoutDaemon ] [06:59:37]: ScheduledRequest[com.inductiveautomation.xopc.drivers.siemens.requests.ReadRequest@c92c658] request with key "1144" failed due to timeout. device-name=Engine_TC_1-8_PLC
INFO | jvm 4 | 2021/09/13 12:29:39 | W [d.S.ReadRequest ] [06:59:37]: Request failed due to TIMEOUT device-name=Engine_TC_1-8_PLC
INFO | jvm 4 | 2021/09/13 12:29:39 | W [d.S.B.TimeoutDaemon ] [06:59:37]: ScheduledRequest[com.inductiveautomation.xopc.drivers.siemens.requests.ReadRequest@4bdd1b56] request with key "14199" failed due to timeout. device-name=PW_Transmission_CutLine_STN1N2_PLC
INFO | jvm 4 | 2021/09/13 12:29:39 | W [d.S.ReadRequest ] [06:59:37]: Request failed due to TIMEOUT device-name=PW_Transmission_CutLine_STN1N2_PLC
INFO | jvm 4 | 2021/09/13 12:29:47 | [38164.691s][warning][os,thread] Failed to start thread - _beginthreadex failed (EINVAL) for attributes: stacksize: default, flags: CREATE_SUSPENDED STACK_SIZE_PARAM_IS.
INFO | jvm 4 | 2021/09/13 12:29:50 | [38166.791s][warning][os,thread] Failed to start thread - _beginthreadex failed (EINVAL) for attributes: stacksize: default, flags: CREATE_SUSPENDED STACK_SIZE_PARAM_IS.
INFO | jvm 4 | 2021/09/13 12:29:50 | [38167.011s][warning][os,thread] Failed to start thread - _beginthreadex failed (EINVAL) for attributes: stacksize: default, flags: CREATE_SUSPENDED STACK_SIZE_PARAM_IS.
ERROR | wrapper | 2021/09/13 12:30:16 | The JVM process terminated due to an uncaught exception: EXCEPTION_ACCESS_VIOLATION (0xc0000005)
ERROR | wrapper | 2021/09/13 12:30:16 | JVM exited unexpectedly.
STATUS | wrapper | 2021/09/13 12:30:21 | Reloading Wrapper configuration...
STATUS | wrapper | 2021/09/13 12:30:22 | Launching a JVM...
INFO | jvm 5 | 2021/09/13 12:30:22 | WrapperManager: Initializing...
The Error it specifies is as below:
# http://www.azulsystems.com/support/
Please suggest
