We are in the process of trying to upgrade to 7.8 from 7.7.2. In doing so every time we do a backup and try restore the Gateway just hangs. By hanging I mean, the Web server service starts but the Gateway stays in a perpetual “starting” state.
I do not attribute this to a 7.8 issue as the issues seems to be tied to our GW backup. I get the same response from our back up on various other dev installs of 7.8. If i use a GW backup of a different GW the problem goes away.
How can I get around this. Is there away to examine the specific GW backup file for issues?
Sorry forgot to add that after about 3 hours the backup finally restores.
I’ve read the issue about the “/” missing from the ignition.conf file. This doesn’t seem to be that issues as I have checked for that and have not seen it.
I have attached the wrapper.log wrapper.log (1.44 MB)
It sounds like what is happening is that the Gateway detected some duplicate entries in the SQLTAG section of the internal database in your backup. It deletes those entries for you upon startup, but for some reason it takes a very long time in this case. Is it possible to generate another backup from the original Gateway? You would have to restart the original Gateway to ensure the duplicate entries have been removed. If you cannot do that, you can also try sending the existing backup to Support to see if they can do something with it.
