com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 3, in onScheduledEvent UnboundLocalError: local variable 'system' referenced before assignment
at org.python.core.Py.UnboundLocalError(Py.java:295)
at org.python.core.PyFrame.getlocal(PyFrame.java:240)
at org.python.pycode._pyx60209.onScheduledEvent$1(:16)
at org.python.pycode._pyx60209.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyFunction.function___call__(PyFunction.java:471)
at org.python.core.PyFunction.__call__(PyFunction.java:466)
at org.python.core.PyFunction.__call__(PyFunction.java:461)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:842)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:824)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:681)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:993)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:746)
at com.inductiveautomation.ignition.common.script.ScheduledScriptManager$ScheduledScriptTask.run(ScheduledScriptManager.java:148)
Caused by: org.python.core.PyException: Traceback (most recent call last): File "", line 3, in onScheduledEvent UnboundLocalError: local variable 'system' referenced before assignment
... 21 common frames omitted
how to declare line 3 in scheduled script? Please help me out @paul-griffith
Do you actually need import system in that script? It is a new-style script instead of an event-style, so I wouldn’t expect it to have this legacy scope problem.
This problem seems to be related to the Scheduled event. My script doesn’t run using the Scheduled event, but it runs without error using the Timer event. Wrapper.log shows the Scheduled event error is UnboundLocalError: local variable ‘system’ referenced before assignment. The first line is:
You shouldn’t need to import system in order to use the system functions within Scheduled Scripts. I’ve been unable to reproduce a situation where it errors, even if you do include it (both on 8.1.7 and 8.1.12).
It does look like if you try to place an import system within an if block like the original post it does indeed produce that error… Just remove that line altogether, you shouldn’t need it.
Anything that starts with system.* e.g. system.db.runPrepQuery had legacy scope intricacies in versions prior to 8, depending on where the code was running.
