Gateway Script Not Outputting Gateway Logs
I can not get my gateway script to output anything to my gateway logger.
For simplicity I have a minimal timer script with a simple log message.
Syntax looks correct, I save the project after each gateway edit and I can see the typical “restarting gateway scripts” after my save. Min log level is “All”. I’m not sure what else to try… This is a copied project I’m duplicating so I thought it might have something to do with inheritance or even enabling the project to be able to write a log?
Is the project itself enabled? Is the project inheritable?
Enabled was it. In another life I had disabled it. Thank you.
