I am currently using ignition Vision version 8.1.14 and OS windows server 2019.
I have configure tags for history there are around 10 tags.
I have to create a xml file everyday at 12:am for last day with reading of 30mins interval.
What is the best way to set this up.
I was exploring the options to create a gateway script to call for name query( MSSQL) and then get data into dataset and converted into pydataset for creating xml file with custom xml schema. I am experiencing issue with Name query with database field t_stamp fields which required to be converted into datatime format doesn’t appear to be easy way to convert this.
I am not sure if i am going correct path or is there any other way to deal with this.
