Gateway scripts not executing after upgrade to Ignition 8.3.4 and HA setup
Environment
  • Ignition 8.3.4
  • Recent upgrade + Gateway Redundancy (HA) enabled
  • Redundant setup: Master / Backup
  • Backup gateway currently in COLD state
Master:
Backup:
Issue summary
After upgrading to Ignition 8.3.4 and enabling HA, Gateway scripts do not appear to execute at all.
Current behavior:
  • No compilation errors
  • Project/scripts save correctly
  • Gateway log shows “Restarting scripts…” after saving
  • No further logs are generated
  • Even very simple timer scripts do not fire, e.g.: system.util.getLogger("MES_DEBUG").info("Timer script FIRED!")
No log output is produced.
Important observation
All Gateway scripts appear to be associated only with the Backup gateway, which is currently in COLD state and not the active/operational node.
Master:
Backup:
At the same time:
  • The Designer is correctly connected to the Master
  • The Master is the active gateway
This raises the question of whether the scripts are incorrectly bound to the Backup node and therefore never executed.
Logging behavior
  • Logs appear inconsistently split between Master and Backup
  • When Gateway-script-related logs do appear, they seem visible only on the Backup logger
  • This makes it unclear where scripts are expected to run in the HA setup
Master:
Backup:
Checks already performed
All checks and troubleshooting steps suggested in the following forum topic have already been completed, without resolving the issue:
  1. Could something have gone wrong during the upgrade or HA configuration?
  2. Do you see any misconfiguration in the described setup, or are there additional checks we should perform?
  3. In an HA environment, how should Gateway Scripts be bound to the Master, considering that script-related logs appear only on the Backup?
Any guidance would be appreciated, thank you in advance
Strange. You should open a support ticket.
(Be aware that scripts only run on the active gateway anyways.)
Hello Phil and thank you.
I opened a ticket with our local distributor and maybe it can be an issue related to v 8.3.4...we will try to upgrade to v 8.6.
However, can you can you specify what you mean by "scripts only run on the active gateway"?
In a redundant system, scripts are only run on the currently active gateway. So looking for scripts to be running on the backup gateway is moot, as they will not run by design.
After powering down the backup server, all scripts and loggers were immediately synced back to the master.
We have since restarted the backup, and everything is functioning as expected.
So, I don't know what happened when we configured the HA, but the old "turn-off-and-on" strikes again.
