Gateway Scripts not Showing on the Gateway
I am starting to feel like my Ignition Gateway is gaslighting me. I have tried multiple different things, such as different projects, timed vs scheduled. No luck.
I don't know what else to try, this doesn't happen on any of our other Prod or Dev gateways. The project is saved, the script is enabled, I am on the correct gateway...... any thoughts? Ver 8.1.47
Is that an inheritable project that has no child (inheriting) projects? Anything in the gateway or designer logs?
Why yes, it is. Does it need to be either not inheritable or a child project?
That project needs to be not inheritable to actively run gateway scripts.
Avoid defining gateway scripts in an inheritable project as every child (inheriting) project will then run those gateway scripts. The same rule applies to transaction groups.
Thank you! That is exactly the issue. :melting_face: Appreciate the help, that makes sense as it is intended to be more of a template.
