Prompted to update Java 7 to update 25 so I did. Upon reboot when launching the project I’m still prompted everytime to update Java even though I have updated and even completely removed and re-installed.
After a few tries of getting Java to work I then noticed that the Gateway service no longer starts.
Here’s the the wrapper log.
Thanks in advance!
wrapper.log (4.78 MB)
I see where the path to Java is incorrect but how can I change it?
In the ‘data’ directory there’s a file called ignition.conf that has the ‘wrapper.java.command’ variable.
ok, I was able to correct the path but the gateway service still cannot be started
Can you post the logs again?
Ah nice catch. I guess I didnt save the updated path. I saved it and rebooted and the service started up fine! Thank you!
