wrapper.log (79.5 KB)
I cannot get the gateway or web server to start. The message I am getting is net helpmsg 3547 . I think java had updated and I did modify the path but this didn’t work. I looked at the wrapper.log file and it is giving me this: " java.net.BindException: Address already in use: bind" There is not a port number or address in the log.
It looks like it’s trying to bind to an incorrect address, 0.0.0.0 port 8043. Perhaps java has not got permissions to access the network? Check what security software you have installed and what it is doing. Also make sure you only have one version of java installed.
I found an additional instance of Java running and it is ok now.
