Hello, I’m trying to access Ignition v8.0.2 downloaded on a Windows7 laptop machine. When I go to start the Ignition Gateway Service I get an error. See text in wrapper.log below. Please advise.
STATUS | wrapper | 2021/07/21 17:39:17 | Launching a JVM…
INFO | jvm 1 | 2021/07/21 17:39:17 | WrapperManager: Initializing…
INFO | wrapperm | 2021/07/21 17:39:20 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:39:25 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:39:30 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:39:35 | Waiting to start…
INFO | jvm 1 | 2021/07/21 17:39:39 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection timed out: connect
INFO | jvm 1 | 2021/07/21 17:39:39 | WrapperManager Error: Exiting JVM…
ERROR | wrapper | 2021/07/21 17:39:39 | JVM exited while loading the application.
INFO | wrapperm | 2021/07/21 17:39:40 | Waiting to start…
STATUS | wrapper | 2021/07/21 17:39:44 | Reloading Wrapper configuration…
STATUS | wrapper | 2021/07/21 17:39:44 | Launching a JVM…
INFO | jvm 2 | 2021/07/21 17:39:45 | WrapperManager: Initializing…
INFO | wrapperm | 2021/07/21 17:39:46 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:39:51 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:39:56 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:40:01 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:40:06 | Waiting to start…
INFO | jvm 2 | 2021/07/21 17:40:06 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection timed out: connect
INFO | jvm 2 | 2021/07/21 17:40:06 | WrapperManager Error: Exiting JVM…
ERROR | wrapper | 2021/07/21 17:40:07 | JVM exited while loading the application.
INFO | wrapperm | 2021/07/21 17:40:11 | Waiting to start…
STATUS | wrapper | 2021/07/21 17:40:11 | Reloading Wrapper configuration…
STATUS | wrapper | 2021/07/21 17:40:11 | Launching a JVM…
INFO | jvm 3 | 2021/07/21 17:40:12 | WrapperManager: Initializing…
INFO | wrapperm | 2021/07/21 17:40:16 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:40:21 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:40:26 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:40:31 | Waiting to start…
INFO | jvm 3 | 2021/07/21 17:40:33 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection timed out: connect
INFO | jvm 3 | 2021/07/21 17:40:33 | WrapperManager Error: Exiting JVM…
ERROR | wrapper | 2021/07/21 17:40:34 | JVM exited while loading the application.
INFO | wrapperm | 2021/07/21 17:40:36 | Waiting to start…
STATUS | wrapper | 2021/07/21 17:40:38 | Reloading Wrapper configuration…
STATUS | wrapper | 2021/07/21 17:40:38 | Launching a JVM…
INFO | jvm 4 | 2021/07/21 17:40:39 | WrapperManager: Initializing…
INFO | wrapperm | 2021/07/21 17:40:41 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:40:46 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:40:51 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:40:56 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:41:01 | Waiting to start…
INFO | jvm 4 | 2021/07/21 17:41:00 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection timed out: connect
INFO | jvm 4 | 2021/07/21 17:41:00 | WrapperManager Error: Exiting JVM…
ERROR | wrapper | 2021/07/21 17:41:01 | JVM exited while loading the application.
STATUS | wrapper | 2021/07/21 17:41:05 | Reloading Wrapper configuration…
STATUS | wrapper | 2021/07/21 17:41:05 | Launching a JVM…
INFO | wrapperm | 2021/07/21 17:41:06 | Waiting to start…
INFO | jvm 5 | 2021/07/21 17:41:06 | WrapperManager: Initializing…
INFO | wrapperm | 2021/07/21 17:41:11 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:41:16 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:41:21 | Waiting to start…
INFO | wrapperm | 2021/07/21 17:41:26 | Waiting to start…
INFO | jvm 5 | 2021/07/21 17:41:27 | WrapperManager Error: Failed to connect to the Wrapper at port 32,000. Cause: java.net.ConnectException: Connection timed out: connect
INFO | jvm 5 | 2021/07/21 17:41:27 | WrapperManager Error: Exiting JVM…
ERROR | wrapper | 2021/07/21 17:41:28 | JVM exited while loading the application.
FATAL | wrapper | 2021/07/21 17:41:28 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2021/07/21 17:41:28 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2021/07/21 17:41:28 | ← Wrapper Stopped
ERROR | wrapperm | 2021/07/21 17:41:30 | The Ignition Gateway service was launched, but failed to start.
ERROR | wrapperm | 2021/07/21 17:41:30 | Please check the log file for more information: C:\Program Files\Inductive Automation\Ignition\logs\wrapper.log
