Ignition.conf file … so much for my weekend of working with ignition
#encoding=UTF-8
Configuration files must begin with a line specifying the encoding
of the the file.
Wrapper License Properties (Ignored by Community Edition)
Professional and Standard Editions of the Wrapper require a valid
License Key to start. Licenses can be purchased or a trial license
requested on the following pages:
Include file problems can be debugged by removing the first ‘#’
from the following line:
##include.debug
The Wrapper will look for either of the following optional files for a
valid License Key. License Key properties can optionally be included
directly in this configuration file.
#include ./wrapper-license.conf
The following property will output information about which License Key(s)
are being found, and can aid in resolving any licensing problems.
#wrapper.license.debug=TRUE
Wrapper Localization
Specify the locale which the Wrapper should use. By default the system
locale is used.
#wrapper.lang=en_US # en_US or ja_JP
Specify the location of the Wrapper’s language resources. If these are
missing, the Wrapper will default to the en_US locale.
wrapper.lang.folder=…/lang
Wrapper Java Properties
Java Application
Locate the java binary on the system PATH:
wrapper.java.command=java
Specify a specific java binary:
#set.JAVA_HOME=/java/path
#wrapper.java.command=%JAVA_HOME%/bin/java
Tell the Wrapper to log the full generated Java command line.
#wrapper.java.command.loglevel=INFO
Java Main class. This class must implement the WrapperListener interface
or guarantee that the WrapperManager class is initialized. Helper
classes are provided to do this for you. See the Integration section
of the documentation for details.
wrapper.java.mainclass=org.tanukisoftware.wrapper.WrapperSimpleApp
Java Classpath (include wrapper.jar) Add class path elements as
needed starting from 1
wrapper.java.classpath.1=lib/wrapper.jar
wrapper.java.classpath.2=lib/annotations-api.jar
wrapper.java.classpath.3=lib/catalina.jar
wrapper.java.classpath.4=lib/catapult.jar
wrapper.java.classpath.5=lib/el-api.jar
wrapper.java.classpath.6=lib/log4j-1.2.15-min.jar
wrapper.java.classpath.7=lib/servlet-api.jar
wrapper.java.classpath.8=lib/slf4j-api-1.5.3.jar
wrapper.java.classpath.9=lib/slf4j-log4j12-1.5.3.jar
wrapper.java.classpath.10=lib/tomcat-coyote.jar
wrapper.java.classpath.11=lib/tomcat-juli.jar
wrapper.java.classpath.12=lib/mail.jar
Java Library Path (location of Wrapper.DLL or libwrapper.so)
wrapper.java.library.path.1=lib
Java Bits. On applicable platforms, tells the JVM to run in 32 or 64-bit mode.
wrapper.java.additional.auto_bits=TRUE
Java Additional Parameters
wrapper.java.additional.1=-XX:PermSize=64m
wrapper.java.additional.2=-XX:MaxPermSize=128m
wrapper.java.additional.3=-XX:+UseConcMarkSweepGC
wrapper.java.additional.4=-XX:+CMSClassUnloadingEnabled
wrapper.java.additional.5=-XX:+CMSPermGenSweepingEnabled
wrapper.java.additional.6=-Ddata.dir=data
wrapper.java.additional.7=-Dorg.apache.catalina.loader.WebappClassLoader.ENABLE_CLEAR_REFERENCES=false
#wrapper.java.additional.8=-Xdebug
#wrapper.java.additional.9=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8000
Initial Java Heap Size (in MB)
wrapper.java.initmemory=256
Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=1024
Application parameters. Add parameters as needed starting from 1
wrapper.app.parameter.1=com.inductiveautomation.catapult.Catapult
wrapper.shutdown.timeout=120
wrapper.jvm_exit.timeout=120
Wrapper Logging Properties
Enables Debug output from the Wrapper.
wrapper.debug=TRUE
Format of output for the console. (See docs for formats)
wrapper.console.format=PM
Log Level for console output. (See docs for log levels)
wrapper.console.loglevel=INFO
Log file to use for wrapper output logging.
wrapper.logfile=logs/wrapper.log
Format of output for the log file. (See docs for formats)
wrapper.logfile.format=LPTM
Log Level for log file output. (See docs for log levels)
wrapper.logfile.loglevel=INFO
Maximum size that the log file will be allowed to grow to before
the log is rolled. Size is specified in bytes. The default value
of 0, disables log rolling. May abbreviate with the ‘k’ (kb) or
‘m’ (mb) suffix. For example: 10m = 10 megabytes.
wrapper.logfile.maxsize=10m
Maximum number of rolled log files which will be allowed before old
files are deleted. The default value of 0 implies no limit.
wrapper.logfile.maxfiles=5
Log Level for sys/event log output. (See docs for log levels)
wrapper.syslog.loglevel=NONE
Wrapper General Properties
Allow for the use of non-contiguous numbered properties
wrapper.ignore_sequence_gaps=TRUE
Title to use when running as a console
wrapper.console.title=Ignition Gateway
Wrapper JVM Checks
Detect DeadLocked Threads in the JVM. (Requires Standard Edition)
#wrapper.check.deadlock=TRUE
#wrapper.check.deadlock.interval=60
#wrapper.check.deadlock.action=RESTART
#wrapper.check.deadlock.output=FULL
Out Of Memory detection.
#wrapper.filter.trigger.1000=java.lang.OutOfMemoryError
#wrapper.filter.action.1000=RESTART
#wrapper.filter.message.1000=The JVM has run out of memory.
wrapper.on_exit.default=SHUTDOWN
wrapper.on_exit.2=RESTART
Wrapper Email Notifications. (Requires Professional Edition)
Common Event Email settings.
#wrapper.event.default.email.debug=TRUE
#wrapper.event.default.email.smtp.host=<SMTP_Host>
#wrapper.event.default.email.smtp.port=25
#wrapper.event.default.email.subject=[%WRAPPER_HOSTNAME%:%WRAPPER_NAME%:%WRAPPER_EVENT_NAME%] Event Notification
#wrapper.event.default.email.sender=
#wrapper.event.default.email.recipient=
Configure the log attached to event emails.
#wrapper.event.default.email.attach_log=TRUE
#wrapper.event.default.email.maillog.lines=50
#wrapper.event.default.email.maillog.format=LPTM
#wrapper.event.default.email.maillog.loglevel=INFO
Enable specific event emails.
#wrapper.event.wrapper_start.email=TRUE
#wrapper.event.jvm_prelaunch.email=TRUE
#wrapper.event.jvm_start.email=TRUE
#wrapper.event.jvm_started.email=TRUE
#wrapper.event.jvm_deadlock.email=TRUE
#wrapper.event.jvm_stop.email=TRUE
#wrapper.event.jvm_stopped.email=TRUE
#wrapper.event.jvm_restart.email=TRUE
#wrapper.event.jvm_failed_invocation.email=TRUE
#wrapper.event.jvm_max_failed_invocations.email=TRUE
#wrapper.event.jvm_kill.email=TRUE
#wrapper.event.jvm_killed.email=TRUE
#wrapper.event.jvm_unexpected_exit.email=TRUE
#wrapper.event.wrapper_stop.email=TRUE
Specify custom mail content
wrapper.event.jvm_restart.email.body=The JVM was restarted.\n\nPlease check on its status.\n
Wrapper Windows NT/2000/XP Service Properties
WARNING - Do not modify any of these properties when an application
using this configuration file has been installed as a service.
Please uninstall the service before modifying this section. The
service can then be reinstalled.
Name of the service
wrapper.name=Ignition
Display name of the service
wrapper.displayname=Ignition Gateway
Description of the service
wrapper.description=Ignition Gateway
Service dependencies. Add dependencies as needed starting from 1
wrapper.ntservice.dependency.1=
Mode in which the service is installed. AUTO_START, DELAY_START or DEMAND_START
wrapper.ntservice.starttype=AUTO_START
Allow the service to interact with the desktop.
wrapper.ntservice.interactive=false
#VERSION - DO NOT MODIFY: 5
