Hi, I am trying to run ignition gateway on AWS. I created a EC2 instance (ubuntu) and installed ignition. After setup, when trying to startup ignition, I got an error. Logs show:
INFO | jvm 1 | 2023/11/14 06:36:25 | I [c.i.i.d.i.NativeLoader ] [06:36:25]: Loading native library: temp/iec618503288703549368741798/libTMWBase.so
INFO | jvm 1 | 2023/11/14 06:36:25 | I [c.i.i.d.i.NativeLoader ] [06:36:25]: Loading native library: temp/iec618503288703549368741798/libTMW61850.so
INFO | jvm 1 | 2023/11/14 06:36:25 | OpenJDK 64-Bit Server VM warning: You have loaded library /usr/local/bin/ignition/temp/iec618503288703549368741798/libTMW6 1850.so which might have disabled stack guard. The VM will try to fix the stack guard now.
INFO | jvm 1 | 2023/11/14 06:36:25 | It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
INFO | jvm 1 | 2023/11/14 06:36:25 | I [g.InternalDatabaseManager ] [06:36:25]: Upgrading schema for module "com.inductiveautomation.opcua.drivers.bacnet"
INFO | jvm 1 | 2023/11/14 06:36:28 | I [g.InternalDatabaseManager ] [06:36:28]: Upgrading schema for module "com.inductiveautomation.eam"
INFO | jvm 1 | 2023/11/14 06:36:28 | Nov 14, 2023 6:36:28 AM java.util.prefs.FileSystemPreferences$1 run
INFO | jvm 1 | 2023/11/14 06:36:28 | INFO: Created user preferences directory.
INFO | jvm 1 | 2023/11/14 06:36:29 | I [IgnitionGateway ] [06:36:29]: Finalizing cleanup operations on internal database...
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.OAuth2ClientManager ] [06:36:29]: Startup complete in 16 ms
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.EmailProfileManager ] [06:36:29]: Startup complete in 15 ms
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.PersistentRecordSecurityLevelConfigService] [06:36:29]: Started up in 0 ms
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.SecurityLevelManager ] [06:36:29]: Started up in 1 ms
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.PersistentRecordIdpAdapterConfigService] [06:36:29]: Started up in 8 ms
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.PersistentRecordIdpAdapterMetricsService] [06:36:29]: Started up in 0 ms
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.IdpAdapterManager ] [06:36:29]: Started up in 0 ms
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.InternalDatabaseRememberedSubjects] [06:36:29]: Started up in 4 ms
INFO | jvm 1 | 2023/11/14 06:36:29 | I [g.OIDCProviderManager ] [06:36:29]: Started up in 8 ms
INFO | jvm 1 | 2023/11/14 06:36:30 | I [t.m.provider ] [06:36:29]: Tag provider initialized. Starting to load tags... provider=System
INFO | jvm 1 | 2023/11/14 06:36:30 | I [t.m.provider ] [06:36:30]: Complete tag loading in 110 ms
INFO | jvm 1 | 2023/11/14 06:36:30 | I [t.manager ] [06:36:30]: Instantiating provider 'default' of type 'STANDARD'
INFO | jvm 1 | 2023/11/14 06:36:30 | I [t.s.internaljson ] [06:36:30]: Redundancy version token not set for provider 'default', will initialize to system version. provider=default
INFO | jvm 1 | 2023/11/14 06:36:30 | I [t.m.provider ] [06:36:30]: Tag provider initialized. Starting to load tags... provider=default
INFO | jvm 1 | 2023/11/14 06:36:30 | I [t.m.provider ] [06:36:30]: Complete tag loading in 56 ms
INFO | jvm 1 | 2023/11/14 06:36:31 | I [i.UserSourceManager ] [06:36:31]: Starting up...
INFO | jvm 1 | 2023/11/14 06:36:42 | I [g.InternalDatabaseManager ] [06:36:42]: Upgrading schema for module ""
INFO | jvm 1 | 2023/11/14 06:36:43 | I [AuditManager ] [06:36:43]: AuditManager starting up...
INFO | jvm 1 | 2023/11/14 06:37:47 | I [A.S.StorageManager ] [06:37:47]: Starting up...
INFO | jvm 1 | 2023/11/14 06:38:52 | I [A.N.NotificationManager ] [06:38:52]: Starting up...
STATUS | wrapper | 2023/11/14 06:39:56 | JVM received a signal SIGKILL (9).
STATUS | wrapper | 2023/11/14 06:39:56 | JVM process is gone.
ERROR | wrapper | 2023/11/14 06:39:56 | JVM exited unexpectedly.
STATUS | wrapper | 2023/11/14 06:39:56 | TERM trapped. Forcing immediate shutdown.
STATUS | wrapper | 2023/11/14 06:39:56 | <-- Wrapper Stopped
