I am trying to download version 8.1 of ignition on a windows. I have tried multiple times and it has failed every time. It gets to the point where I can select ‘Finish’ and then it says it is opening Gateway. I then get a screen saying Gateway Startup Issue and that more information can be found in the wrapper logs. Any help is appreciated!
Here is a copy of the wrapper logs:
STATUS | wrapper | 2021/05/11 09:12:19 | Launching a JVM…
INFO | jvm 1 | 2021/05/11 09:12:19 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2021/05/11 09:12:19 | JVM exited while loading the application.
INFO | wrapperm | 2021/05/11 09:12:23 | Waiting to start…
STATUS | wrapper | 2021/05/11 09:12:24 | Reloading Wrapper configuration…
STATUS | wrapper | 2021/05/11 09:12:24 | Launching a JVM…
INFO | jvm 2 | 2021/05/11 09:12:25 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2021/05/11 09:12:25 | JVM exited while loading the application.
INFO | wrapperm | 2021/05/11 09:12:28 | Waiting to start…
STATUS | wrapper | 2021/05/11 09:12:29 | Reloading Wrapper configuration…
STATUS | wrapper | 2021/05/11 09:12:30 | Launching a JVM…
INFO | jvm 3 | 2021/05/11 09:12:30 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2021/05/11 09:12:30 | JVM exited while loading the application.
INFO | wrapperm | 2021/05/11 09:12:33 | Waiting to start…
STATUS | wrapper | 2021/05/11 09:12:34 | Reloading Wrapper configuration…
STATUS | wrapper | 2021/05/11 09:12:35 | Launching a JVM…
INFO | jvm 4 | 2021/05/11 09:12:35 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2021/05/11 09:12:35 | JVM exited while loading the application.
INFO | wrapperm | 2021/05/11 09:12:38 | Waiting to start…
STATUS | wrapper | 2021/05/11 09:12:39 | Reloading Wrapper configuration…
STATUS | wrapper | 2021/05/11 09:12:40 | Launching a JVM…
INFO | jvm 5 | 2021/05/11 09:12:40 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2021/05/11 09:12:40 | JVM exited while loading the application.
FATAL | wrapper | 2021/05/11 09:12:41 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2021/05/11 09:12:41 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2021/05/11 09:12:41 | ← Wrapper Stopped
ERROR | wrapperm | 2021/05/11 09:12:42 | The Ignition Gateway service was launched, but failed to start.
ERROR | wrapperm | 2021/05/11 09:12:42 | Please check the log file for more information: C:\Program Files\Inductive Automation\Ignition\logs\wrapper.log
