I am using Ignition 8.0.7 with SSL.
Under gateway network, I have forced the traffic to go through HTTPS. I have the certificate installed and am able to launch the client using client launcher.
I have a local computer which also has a project and acts as a fallback when it can’t connected to primary or secondary ignition server. As part of retarting the script from the local fallback, i check the gateway status and I use the following code.
primary_gatewayadd = system.tag.read(“IP of the primary ignition Server in Memory type string”).value
the value is like : ip:8043/main
status = system.util.getGatewayStatus(primary_gatewayadd)
print status
when I print the status it returns ERROR: Unexpected end of file from server Also when i used ip:8088:8043 it returned with Unknown status.
Please note on the local computer I also have the firewall disabled. The certificates are installed under .ignition/clientlauncher-data/certificates folder.
Please advice
