Ignition 8.1.20
I realised that one of my Perspective applications wasn’t collecting data. The status log reported
File "", line 3, in NameError: name 'productionLogging' is not defined
Details
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 3, in NameError: name 'productionLogging' is not defined
at org.python.core.Py.NameError(Py.java:261)
at org.python.core.PyFrame.getname(PyFrame.java:257)
at org.python.pycode._pyx4221.f$0(:3)
at org.python.pycode._pyx4221.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1687)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:796)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:819)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:748)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:800)
at com.inductiveautomation.ignition.common.script.TagChangeScriptExecutor$TagChangeExecutionCallback.execute(TagChangeScriptExecutor.java:242)
at com.inductiveautomation.ignition.common.script.TagChangeScriptExecutor$TagChangeExecutionCallback.execute(TagChangeScriptExecutor.java:194)
at com.inductiveautomation.ignition.common.util.SerialExecutionQueue$PollAndExecute.run(SerialExecutionQueue.java:102)
Caused by: org.python.core.PyException: NameError: name 'productionLogging' is not defined
... 19 common frames omitted
productionLogging is defined and listed.
I opened the project and saved it without changing anything and it and the scripts are now executing.
Has anyone seen a similar problem?
