Gateway Tag Change Script Interface -- tag list
Hi, I have a simple question about tag list. I saw in ignition manual, wildcards can be used at the end of configured tag paths. For example, [provider]folder/*. But when I tried to use this feature, it didn’t work. I wanna know why and how can I fix this.
Hello, just wondering if you found a solution to this issue. I am currently dealing with the same problem.
I think its not possible. You can't also define the list dynamically . IA may throw more light.
The warning in the diagnostics is wrong. This works fine. The only bug is that the diagnostics is wrong.
A fix for the incorrect diagnostics panel warning has been made, the updates will be available in 8.1.34 as well as in the nightly builds
